Strange problem with Autocad 2017:
When I do a viewport color overrides for layers, it works only when I am in wireframe.
Example: a Layer is in RED. In a viewport, I select the layer and put viewport color overrides so it will be BLUE.
In the properties manager for the viewport, the shade plot is settled to wireframe
On my screen or when I print, the layer will be as expected in BLUE.
I change the properties for the viewport so the shade plot is set to 3d Hidden or to Legacy Wireframe.
On my screen the layer is still in BLUE. But when I print, it is in RED.
The ONLY THING that was changed is the shade plot option in the viewport properties.
This was not happening when I was working with autocad 2013 or 2014.
A friend tried and it happens as well on his autocad 2016.
It happens for all layers.
If I create a new drawing from an original autocad template, it does not happen. But for all the drawings I’ve been working on for a while, it happens.
