Viewport Issue
Viewport Issue
jonathan36LP7
Viewport Issue
jonathan36LP7
I made an irregular viewport in paper space, but unfortunately there are still images outside the viewport clip.  I tried to make another clip using a circular viewport, but apparently there are still images outside the circular viewport. I checked several forums already and found no solution.
cadffm
Either you have two viewports or there is a problem with the layout / view window.
If you delete your circle-viewport, disappear all model-"views" from Layout?
Open file with RECOVER
try command AUDIT (option: Yes)
Try a new viewport
If the problem persists:
Create a NEW layout and a new view window.
Sebastian
imadHabash
i suggest to install the latest service pack for your AutoCAD version. >> Click <<
Imad Habash
jonathan36LP7
Yes, if i delete the circle-viewport, the model-view will be gone in the layout.
I even tried to create new viewport or layout but the result is still the same.
jonathan36LP7
I'm currently using the autocad 2015 and the software is updated up to date.
kadmonkee
lock your viewport
open the viewport
with the viewport open draw the shape of your viewport on Defpoints layer in model space and make theat your clip boundry.
the image is not scale properly to show the shapes match
model space = red
confirm your model space and vieport scale match and this should work for you.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
jonathan36LP7
Everything was solved by restarting my computer. I don't know what happened but the viewport were fixed after I opened the file on the next day.
