VIEWPORT IS NOT LOCKED, BUT ZOOMABLE, AND NOT ERASABLE
TECHSERVICES
TECHSERVICES
I GOT A VPORT THAT I CANNOT WINDOW PICK TO ERASE... ITS LOCKED BUT STILL ZOOMABLE.
0 Me gusta
Responder
Soluciones aceptadas (1)
384 Vistas
4 Respuestas
Respuestas (4)
Alfred.NESWADBA
What happens when you click onto it?
Or is the viewport's border not visible? ==> in that case look for layers frozen or turned off.
If you can select the viewport's border, but using <DEL> key does not remove it it might be on a layer that is locked.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
john.vellek
Solución aceptada
Hi @TECHSERVICES,
I am a little confused by your description of your issue. If the Viewport is locked you are indicating that you can zoom in it? Do you mean the actual scale of the view is changing?  Is it possible to attach your file to a post so I can see what you are seeing?
You might check to see what layer the viewport is on (and whether or not it is locked) and you might also check to see if it is actually an xref or something else.
I am happy to take a look if you can share it.
John Vellek
0 Me gusta
Kent1Cooper
Could it be that it's on the DEFPOINTS Layer [bad but common practice] and  Layer 0 is either turned off or frozen?  That would have the effect you describe, if I'm understanding correctly.
Kent Cooper, AIA
TECHSERVICES
mview layer was locked... i scrolled thru my layers prior and didn't notice...thanks all!!
side bar:  is mview a common layer name for non.printable vport windows?
0 Me gusta
