Viewport Deleted, View Still Visible
KaitlinUlrich
Message 1 of 22
KaitlinUlrich
Has anyone ever erased a viewport, but had the view stay? I am 100% sure I deleted the viewport, and that it is not on any frozen or off layers. The view that the viewport was housing however, did not disappear. Additionally, when I pan around the page, the visible parts of the view move. I have tried selecting what remains, but CAD doesn't recognize that anything is there. When I go to print however, the view is still there. Can anyone tell me how to delete this view if there isn't a viewport?
Replies (21)
Message 2 of 22
Patchy
Shut down and restart Autocad, is it still there?
Message 3 of 22
KaitlinUlrich
Yes it is. I have also regenerated many times
Message 4 of 22
cadffm
Delete all you can,
Use command LIST ALL
What is the feedback? [F2]
OR SHARE YOUR FILE
Sebastian
Message 5 of 22
KaitlinUlrich
The feedback was all my recent commands, which is only 'select objects'. Unfortunately I am unable to share the file as it is a company project.
Message 6 of 22
cadffm
Sounds like an INVENTOR dwg,
Are there Blocks with the same content?
Ckeck out which blocks are in your dwg.
Comman block or insert or ACD
Sebastian
Message 7 of 22
KaitlinUlrich
Its CAD for Architecture, sorry, should have specified that before
Message 8 of 22
cadffm
You have cad data, we have the knowledge.
Lets come together and share
Sebastian
Message 9 of 22
pendean
Community Legend
Community Legend
@KaitlinUlrich
If panning moves the content, then you are INSIDE a viewport (outline is on a frozen layer you did not thaw yet or is it out of view) or your content is actually in LAYOUT and not in a viewport.
Wondering what you see here, MODEL or PAPER? or do you have that turned off? AutoCAD loves to feed you information.
Message 10 of 22
KaitlinUlrich
I'm in paper space. All other viewports are normal, only one is corrupt
Message 11 of 22
Patchy
Unlock all layers then run autolisp:
(defun c:DelVP (/ ss)
  (vl-load-com)
  (cond ((eq "Model" (getvar 'ctab))
         (alert "** Command not allowed in Model Tab **")
        (t
         (if (setq ss (ssget "_x" (list '(0 . "VIEWPORT") (cons 410 (getvar 'ctab)))))
           (repeat (setq i (sslength ss))
             (vl-catch-all-apply
               'entdel
               (list (ssname ss (setq i (1- i))))
  (princ)
Message 12 of 22
KaitlinUlrich
When I do turn on model in page view, it acts like there is another view that's underneath the original view, and I can move the second around, but the first stays stationary.
Message 13 of 22
cadffm
Follow my hint about inventor / blocks!
delete all things,  purge all, check your blocks...
I think you will find blocks with the content which you can see in your Layout.
Isn't it?
Sebastian
Message 14 of 22
pendean
Community Legend
Community Legend
So your content is actually drawn in paperspace. There is no viewport.
Message 15 of 22
KaitlinUlrich
What's in the view isn't in a block, it was drawn originally in model space for this file specifically, isn't grouped, blocked, or anything. Is that what you mean?
Message 16 of 22
pendean
Community Legend
Community Legend
....Is that what you mean?
it's time you shared your DWG file please: ask for permission if needed. TIA
Message 17 of 22
KaitlinUlrich
No, its drawn in model space, its showing up in paper space because there was a viewport there before I deleted it. But when the viewport was deleted, the window into model space didn't delete. When I try to select what I'm seeing in paper space, on Paper mode, CAD doesn't acknowledge that anything is there
Message 18 of 22
cadffm
Is okay, I guessed wrong.
Again: Share your data for the best and fastest answer..
Sebastian
Message 19 of 22
pendean
Community Legend
Community Legend
...CAD doesn't acknowledge that anything is there
Message 20 of 22
technicalXATQP
HI I know it's the historical post but I have EXACTLY the same problem. autocad creates 'invisible' viewport which I can not delete because it doesnt have borders. I can move my viewpoert, control layers on it,  switch on and off but on the 'viewport' Autocad creates everything stays on, and I cant control or or even select it. Even if I delete everything from the paper space the 'viewport' stays on, I can not select it because it doesnt have borders. I have updated Autocad (2026), restarted machine, purged, audit, even created a new file. Nothing helped.
Files attached
I am in panick station, as there's a lot of tabs and recreate them all would be a massive job.
