Viewport Controls Toolip
kstate92
kstate92
This is a very minor annoyance, but it's akin to a paper cut that never heals.
I have a dual monitor setup with AutoCAD (now 2017 but 2014 did it too) on the second monitor on my right.  Frequently, when moving the mouse pointer from within AutoCAD to another application on the other (left) monitor, I clip the Viewport Controls widget that is very close to the edge (no toolbars or palettes on the left edge of the AutoCAD window).  When I do so, the tooltip comes along for the ride and stays visible and on top of the other application, such as shown below.  Once triggered, I have to go back to AutoCAD (gain focus) to turn the tooltip off by hovering somewhere else for a second.
Yes, before someone helpful swoops in, I know I can turn off tooltips, thanks.  That's not my point.  I think this is a bug in that I don't think a tooltip should be able to flip outside the application window, but if does, it certainly shouldn't be allowed to persist after losing focus.  Though, as I write this, maybe that means it's more of a graphics driver issue than the application per se?  I am running the recommended AutoCAD driver for my graphics card, BTW.
I did a quick glance thru Options for 'Viewport Controls' as I'd be more than willing to turn off that which I've never, ever used, but I didn't find anything.  Clicking on the [-] brings up a menu where only the ViewCube is checked (which I do use and keep visible), but nothing that looks related to turning the control off.
I'm mainly wondering if others have this same irritating cut.
KState92
Inventor Professional 2020
AutoCAD Mechanical 2022.0.1
Windows 10 Pro 64 bit - 1903
Core i7-8700 32 GB Ram
Quadro P2000
user181
Hi @kstate92,  If you want to turn off the viewport controls change the variable VPCONTROL  to off
kstate92
Oh, FFS how did I miss that?
But yes, that's exactly what I needed.
Thanks.
KState92
Quadro P2000
