I have a file with 18 layout tabs. 2 of these tabs are not plotting correctly. Plot preview of the files show them correctly, but when plotting to pdf, they do not plot correctly. After a few hours of troubleshooting, I have narrowed it down to this:
If I shift the contents of the viewport (as in double click inside the viewport and pan to a different view in model space) then plot, everything works as it should. When I have the viewport set where I need it to be, everything except the floorplan background disappears when I plot the tab to pdf. I have a titleblock and text in the layout tab, and 2 viewports, one is a section of the floorplan and the other is an overall site plan. All of the other 16 tabs plot correctly except these two. Model space has the overall floorplan, symbols and wiring. Everything disappears except for the floorplan. I have completely recreated this tab in its entirety and the problem still exists. I have copied components of other working tabs, and the problem still exists. If I shift the contents of the viewport away from the area I need, everything plots correctly. Help?!
