ViewCube Issues
ViewCube Issues
cmcinhk
Message 1 of 10
ViewCube Issues
cmcinhk
So I'm new to AutoCAD but I am very experienced in CAD in general like Solidworks or Fusion. Right now I am stuck on something which seems very basic, changing the view. I can freely pan around but clicking on the sides of the viewcube doesn't do anything, and if I change it from the viewport options on the upper left corner or in the view menu only 'top' works. This is very annoying and kinda unusable right now.
Chris
Replies (9)
Message 2 of 10
Alfred.NESWADBA
Are you inside a viewport (on a layout) and the viewport is locked?
If not try to restart AutoCAD, create a new drawing and try again to click on edges or corners of the viewcube.
Also make sure your AutoCAD is updated, if you don't know if it is or not start command _ABOUT and show us a screenshot of that dialog.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 10
ChicagoLooper
Are you trying to change the drawing plane? The viewcube merely changes your vantage point so you can see your 3D object from different angles. To change or select your drawing plane go to View tab>Views panel.
Chicagolooper
Message 4 of 10
cmcinhk
- alfred -
I'm pretty sure it's not locked because I can freely pan and switch between top and bottom, I just can't go to right, left, front and back.
Restarting AutoCAD doesn't work. I tried to save as a new file but the problem still persists.
I'm also pretty confident it's up to date as I only installed it a few days ago.
I attached a video of my issue here:
Message 5 of 10
Alfred.NESWADBA
can you try the same please with a new dwg-file based on an original AutoCAD template?
- alfred -
Alfred NESWADBA
Message 6 of 10
ChicagoLooper
What does your View Manager look like. Can you please upload a screen shot?
View tab>View panel>Named Views. Is something in the view manager overriding your 'preset' views?
View Manager.View Manager.
Chicagolooper
Message 7 of 10
cmcinhk
Here is my View Manager. If I try to change it in here (Right/Left/Front/Back -> Apply -> OK) it doesn't work either.
Message 8 of 10
ChicagoLooper
Hmmm....Here's an Autodesk AKN on viewcube rotation. Click >>HERE<< to read it. It's dated 2015 but might still be beneficial.
Chicagolooper
Message 9 of 10
cmcinhk
The guide says to check GPU compatibility and update drivers.
I'm running a GTX 1060 which isn't officially supported but other people seem to be just fine with it.
Also, updating my GPU drivers doesn't work.
I'll try uninstalling and reinstalling but not sure what else to do.
Message 10 of 10
cmcinhk
Nevermind I fixed it. Instead of saving as a new file I created a new file and then copy & pasted everything over.
Should have tried that first.
