How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Whenever I draw in a metric template, Viewbase is flipped when I'm creating projected views.
The best way to explain it is that the views are flipped along the x axis.
Does anyone know of the variable that is changed between the two?
Attaching the dwg templates with the same object.
I would guess that the Imperial is set to 3rd angle projection, and the Metric one is set to 1st angle projection.
ection.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
you can setup the direction of projection, using command _VIEWSTD brings you this dialog to configure the projection direction:
Then make this drawing to your new template.
- alfred -
Choose the correct Projection Type
Jürgen Palme
How to buy
Type a product name
