Viewbase command to create live link between AutoCAD and Inventor (Views don't get updated)
ali_jahed
ali_jahed
Hi All,
I have a problem here using viewbase command.
When I update a view in Inventor (let's say turn the visibility of a component On->Off) and save the assembly file, the view in AutoCAD doesn't get updated. I found a way around it by toggle the views as shown in below then it gets updated!
Is there a better way of doing this?
imadHabash
As much as i understand your need ....
have you tried VIEWUPDATE command.
Imad Habash
ali_jahed
I Did update view, update All ..., didn't work!
CGBenner
@ali_jahed
Hello!  I can see in your image in the first post that you use AutoCAD 2024, what version of Inventor do you use?
Chris Benner
ali_jahed
Inventor is 2024.
Funny enough if I change the length of a section the update works but when I change alter  the View doesn't get updated!
ali_jahed
Note for future reference, File in AutoCAD must get closed and reopen for any update.
I realized when I create different Model States the updated happens with no problem (Suppress works).
Visibility which control the View doesn't work!
Also, I realized, if I create a new View it doesn't show up under the dropdown selection however for Model State there is no problem.
Hopefully, someone comes back with an answer.
