View shape dimensions
I'm completely new to AutoCAD. I've drawn rectangles by inputting length and width in mm, and after doing this I would expect to see these dimensions showing somewhere in the Properties panel for that shape. In the Geometry section of Properties I can see various figures but none of them are the dimensions of the rectangle that I inputted. Am I looking in the wrong place for the dimensions or is that I'm not building the shape in the right way?
Kent1Cooper
A rectangle made with the RECTANG command is just a Polyline.  Once it's drawn, AutoCAD doesn't know it was made with that command, as opposed to having been drawn point by point, or made with the POLYGON command as a square and maybe STRETCHed, or originating from four Lines and joined together with JOIN or PEDIT's Join option, etc.  There is no entity type called a rectangle, nor any rectangle "property" of such a Polyline -- it's being rectangular is just a matter of the positional relationship of its vertices, and nothing else about it distinguishes it from any quadrilateral shape.
But if you have Dynamic Input turned on [F12 key -- the DYNMODE System Variable], you can just pick on it, and hover the cursor over any of the corner grips, and you'll see the lengths of the adjacent edges.
Kent Cooper, AIA
