Anuncios
View drawing views in lower CAD version
No aplicable
I created a 3d model and use command "viewbase" to create some drawing views in AutoCAD 2018 ,then saved my drawing as AutoCAD 2004 drawing .But you know,not everyone have new version of CAD, when my colleague open my drawing in AutoCAD2008, other things are good, but drawing views seems in a mess. How can he view drawing views collectly, or what can I do?
By the way,  why drawing views can't be copied or exploded in AutoCAD 2018? Sometimes I want to edit the lines.
0 Me gusta
Responder
Soluciones aceptadas (1)
460 Vistas
4 Respuestas
Respuestas (4)
Alfred.NESWADBA
Solución aceptada
Drawing views are objects introduced much later than AutoCAD 2004 was released. And so these objects are one of those that were not able to be saved back to older releases.
The chance you have is to use _EXPORTLAYOUT to get them saved as plain lines and arcs, theses type of objects can then be save back to older versions of dwg-format.
If you need to exchange data from your quite current AutoCAD 2018 with software that is more than 10 years old then you should only use objects and object-properties that were available in that old releases too.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
No aplicable
thank you,I think he can view now. ButI think if drawing views can be edited in CAD2018 is better.
0 Me gusta
neaton
VIEWBASE objects in paper space are intelligent objects so any modifications need to be done to the 3D objects in model space. The viewbase objects are representations of the 3D model, not the 3D model itself so they can't currently be modified from paper space.
If you would like to suggest this ability be added to AutoCAD go to the AUGI (Autodesk Users Group International), sign up and add it to the wish list. More on the AUGI wishlist >>here<< and >>here<<. AUGI is not part of Autodesk but since Autodesk doesn't have an AutoCAD idea board AUGI is the place to add suggestions for new or improved features.
Nancy
0 Me gusta
neaton
Most new AutoCAD features are not backward compatible as @Alfred.NESWADBA said. Some intelligent objects (centermarks) will explode and not be intelligent anymore, but others (viewbase objects) aren't backward compatible.
CAD Forum has a list of all commands and system variables and the date they were added to AutoCAD https://www.cadforum.cz/cadforum_en/variable.asp. You may need to register with CAD Forum to view the list.
Nancy
0 Me gusta
