I currently use Autocad to produce Arrangement Drawings for large structures. I work in any program and export 3d dwg files into model space. then illsutrate different aspects of the structure using viewports in paper space.
When producing section views, elevations and multi level plan views, I have had issue from filtering out what I do and dont want to show in a viewport.
For example, when i want to show a first floor plan view, the steel work illustrated for second floor is also shown overlapping.
Using other software I have been able to produce section views with set view depths, but i cant find any equivalent to this on Autocad. Is there any such option to limit view depth? The only option i have found it to do additional layers for every floor, and perspective.
an example of what i mean from the software, tekla, is below
john.vellek has embedded your image(s) for clarity
