VIEW CULLING BREAKING TRIM
gcarvac
gcarvac
I am using the trim tool to remove a line. Because my item is quite large, I need to zoom in to select the correct line to trim. Unfortunately, this means the intersecting lines are outside my view. The trim tool then removes the entire line instead of up to the intersecting lines. Is there a way to improve this?After trimAfter trimBefore trimBefore trim
gcarvac
Sorry for the shouty title, have caps lock on by default
RobDraw
Your pictures don't adequately show what your doing or trying to do. My guess is that you are in Quick Mode for trim and it's causing a problem when intersections are off screen.
Rob
Valentin_CAD
@gcarvac ,
@gcarvac wrote:
... The trim tool then removes the entire line instead of up to the intersecting lines. ...
The line may not be on the same plane as mentioned on this link :
        Consider using the FLATTEN command or adjusting the Z value in the Properties.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
pendean
Community Legend
Community Legend
@gcarvac Any reason you don't want to just "hide" the objects you don't need on screen first? The option is right there in your right-click menu when you select them under "isolate", explore.
