View Cube Not an Option
I have read the forums for the View Cube disappearing but every time I follow the solved questions, nothing has worked. I have typed multiple commands but nothing has worked.
Attached is a screenshot of my Options>Display box but 2D Wireframe or ViewCube are not shown. Is there something I am missing?
ctanto333
Try this method may be your problem will be solved.
type "NAVVCUBE"  then select the option "Settings"  then "Restore Defaults" then select "OK", again type "NAVVCUBE" then select the option "ON". Now your view cube will be visible.
Thank You.
Hi! I tried this command along with others but it always responds with unknown command when I type "NAVVCUBE."
Looks like ViewCube might not be available with AutoCAD LT. Thank you for trying!
pendean
Community Legend
Community Legend
rkmcswain
@Anonymous  - that's because you appear to be running AutoCAD LT.
NAVVCUBE is not a valid command in AutoCAD LT.
You have posted your query in the AutoCAD forum BTW. You may wish to ask in the AutoCAD LT forum.
R.K. McSwain     | CADpanacea | on twitter
