Video Card Technical Problem
AutoCAD 2017 is extremely slow.
When I start the program a pop-up appears and tells me that my video card (Nvidia GTX 1060 6GB) doesen't meet the requirements of AutoCAD.
I have seen these requirements and I think that my video card is enough for run smoothly AutoCAD.
Please I need help. I have to fix this problem because it's impossibile to do anything due to slowness.
Thank you.
Alfred.NESWADBA
Hi,.
please start command _GRAPHICSCONFIG and in that dialog click on "restore defaults" (lower left), then restart AutoCAD and see if that works then (if not please show us a screenshot from that dialog of the above command).
Also try to update or downgrade the graphic card driver and make sure your AutoCAD is fully updated (command _ABOUT should show 2017.1.2)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
