Anuncios
vertical dimension problem
No aplicable
pls help.. all my vertical dimension always lack 2mm from the actual size of the drawing.. horizontal and other dimensions seems fine only the verticals not working correctly.. i did not edit the settings from my standard dimension style.. pleas see the attached picture it might help.. thanks!
0 Me gusta
Responder
Soluciones aceptadas (1)
1.380 Vistas
3 Respuestas
Respuestas (3)
imadHabash
dimensions is always read your points entering ... to get accurate answer please attache here your drawing ? i'm afraid that your vertical dim read the distance for the vertical magenta line not to the diameter real distance.
Imad Habash
No aplicable
sir see pls see attached cad file.. test the vertical dimensioning.. its always wrong
0 Me gusta
imadHabash
Solución aceptada
as seen from below image ... there is NO problem at all. i suggest to put dim on your drawing and attache it here.please we don't need all of your drawing just attache your case. :cara_con_una_leve_sonrisa:
Note : i'm afraid this issue related to your osnap mode.
Imad Habash
