Vehicle tracking disappears in other cad software
abdt214
Observer
abdt214
Observer
Observer
Hello
I have recently been having issue with vehicle tracking swept path analysis. I use autocad to create the swept path and open the same file in another cad software briscad that i use primarily and the vehicle tracking lines etc disappear. All I am left with are rectangular boxes where the swept path should be.
Any advise on this
Thank you
imadHabash
i suggest to read this link >> Click << that may give you a hint to start from .  also you can get more help here >> Click <<
Imad Habash
Apex-Solutions
@abdt214
Which Cad software are you referring to when you say "other CAD software"
If the other CAD software is an AutoCAD on a different computer then you would need to install object enablers for Vehicle tracking.  You can find Vehicle tracking object installers for 2018 and 2019 on the respective hyperlinks.
I do not believe that these object enablers would be worth for a product outside of the Autodesk scope.
If the other CAD software that you are referring to falls outside of the Autodesk scope then you might need to explode the vehicle tracking object in order to have the objects display as lines and polylines.
As mentioned by @imadHabash your forum post for vehicle tracking would be received better on the Vehicle tracking forum.
Kind Regards
Marnus van Staden
N.DIP Civil Engineering | Senior Technical Specialist
Autodesk Trainer | Draughting Consultant
________________________________________________________________________________________________
If you find my post useful, please give me Kudos. If my post solved your problem, please accept it as a solution.
Apex Solutions Youtube Channel
abdt214
Observer
Observer
thank you very much sir
that solved my problem, I might have played with those exact same settings not knowing they would affect the vehicle tracking
thank you very much once again
