Variable behavior of OFFSET command
Jeew-m
Mentor Mentor
Jeew-m
Dear All,
Attached dwg is a polyline.
I need to offset it twice with 3.6m width to the left.
First 3.6m works well.
Next one it says 'cannot offset that object.'
If I offset 3.6m and then 3m and then 0.6m it works.
If I offset 7.2m (which is 3.6*2) at once it works.
Why is this behavior.
Thanks in advance.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
imadHabash
it will be solved if you FLATTEN ( N ) your polyline first . but i have some notes :
  • your file need Audit and Purge ( Regaapps ) .
  • the offset distance ( 3.6 ) it's too small or very tight compare with the polyline length ( 36495 ) .
  • your polyline consists of of thousand of attached peaces and i beleive that this will make problems and delayed issues .
Imad Habash
Jeew-m
Thanks for the answer.
Flatten with remove hidden lines NO does not work.
I did the others as well. But same result.
This is a lane offset of a road.
There is a way to achieve this. . But I am curious to know why it behaves strangely in the normal procedure.
Jeewana Meegahage
Design Engineer
imadHabash
would you please try to Ctrl+C the polyline to a new blank dwg then FLATTEN it and see if any changes .
Imad Habash
cadffm
EDIT:SORRY, My translation problem. Not to each side. You want offset to the left and the new object offset with 3.6 to th left too.
7772 Segments is hard stuff.
I know about these problems, BUT:
I can offset them in each direction with 3.6 with 2018.1.1 also with 2013 SP2, which version are you using?
Do you tested it in THIS attached dwg yourself?
Sebastian
cadffm
@Jeew-m
You work in a high coordinate range, there are often problems
and especially the offset command is a bit buggy (more than in other software products)
I use for such own functions or simple macros and the standard functions.
move to 0.0
make what i want (hatching, stretching or offsetting)
move back
Try it, it wants work.
Sebastian
Jeew-m
Thanks CADffm.
That really works fine. So this is because of high coordinate range.
Thanks everyone for comments.
Jeewana Meegahage
Design Engineer
