Using wildcards
Using wildcards
114729SNYMQ
Observer Observer
Message 1 of 8
Using wildcards
114729SNYMQ
Observer
Observer
Hello everyone.....
I received a DWG with several Mtexts like:
[Z= -0.252]
+0.002
So a Mtext with 2 rows
But all with different numbers, see attachment
I want to find and replace all of them to a text that just contains the first number, so in this case
-0.252
How do i use the wildcards in find and replace?
Replies (7)
Message 2 of 8
paullimapa
sounds like something that will require lisp
you may want to post this in that forum and also include a sample dwg:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
Paul Li
IT Specialist
@The Office
Message 3 of 8
Pointdump
Hi Vincent,
An interesting problem. Can you post your drawing?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 4 of 8
ВeekeeCZ
Isolate them, move them to new drawing.
Explode them.
Find and remove all *.###
Then replace "[Z= " and "]" with nothing.
Easy.
Message 5 of 8
Pointdump
Hi @ВeekeeCZ,
"Easy."
Uh huh. What about the lower line of the MText? And how to return the filtered text back to being a Leader?
Dave
Dave Stoll
Las Vegas, Nevada
Message 6 of 8
Valentin_CAD
@114729SNYMQ ,
Certainly, an interesting topic. As mentioned, this may be a task for the Visual LISP, AutoLISP, General Customization Forum Autodesk.
It's a challenge because the [ is considered a wildcard and "Find and Replace" will not work.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 7 of 8
ВeekeeCZ
@Valentin_CAD wrote:
@114729SNYMQ ,
You need to use a reverse quote sign per the last line of your screenshot
Message 8 of 8
Valentin_CAD
@114729SNYMQ ,
Good point @ВeekeeCZ !
So, here is a tedious option, but it resolves:
Your example:
Use ?0.0## to remove the second line:
Then, use `] to remove the end bracket:
Lastly, use `[X= to remove the front portion:
Emilio Valentin
