Using StartApp
jwright1962
Using StartApp
jwright1962
For years I've used StartApp to start "explorer" and open a folder where I keep my collection of lisp files.   I've cut and pasted the same little code snippet out of the toolbar button from a prior version of Cadd I was using.  Now, the durn thing only starts "explorer" in "Documents"...   I pasted the same durn thing to the command line and it opens explorer in the root directory of the C drive...  Whiskey Tango...?
This has worked for years...
^C^C(startapp "explorer" "C:/lsp")
but now... it does not.
any help out there?   Thanks Forum!!
0 Me gusta
Responder
Soluciones aceptadas (1)
2.240 Vistas
9 Respuestas
Respuestas (9)
TheCADnoob
try
^C^C(startapp "explorer" "C:\\lsp")
CADnoob
0 Me gusta
paullimapa
You can also try this passing a number explorer command line parameters all in one shot:
(startapp "explorer.exe /n,/e,/select,c:\\lsp")
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
0 Me gusta
jwright1962
Thanks to both previous replys.  I've tried both but neither work.   I've tried every combination I can think of with forward slash, back slash, no slash. but nothing seems to work.
(startapp "explorer" "c:\\lsp")   This works on the command line only but not when pasting exactly the same in a toolbar button
0 Me gusta
paullimapa
Solución aceptada
Try defining a new lisp command function like OpenLsp and then enter this new command in the Toolbar ie:
(defun C:OpenLsp () (startapp "explorer" "c:\\Lsp"))
Then in the Toolbar enter:
^C^COpenLsp
Paul Li
IT Specialist
@The Office
rkmcswain
@jwright1962 - what changed in between the time it was working and now?
I know it sounds silly, but have you rebooted the PC?
jwright1962
OK, I have it resolved.
I'm not sure what changed but I've tried every combination I could think of ...  "to slash or not to slash".  What worked was creating a separate lisp in my "lsp" folder; adding that lisp file as an autoload in acaddoc.lsp and then calling the function in the button as suggested above...  OpenLsp   this worked fine.   I was hoping not to have to manage more lisp overhead to get it to work but it is what it is... and it works as suggested above.   Actually; not a big deal to manage the lisp files.   I have a "ton" of general "utility" lisp files I use quite frequently and it's nice to have a single click to bring up my lsp folder rather than clicking several times in Windows to get to that folder "outside" of cad.
0 Me gusta
paullimapa
Glad this worked out for you...cheers!!!
Paul Li
IT Specialist
@The Office
0 Me gusta
rkmcswain
BTW: I prefer using the method of @paullimapa because it's easy to quickly make a change to a lisp file, but getting into the CUI and editing and testing menu macros can be more time consuming. So you put the never changing pointer in the CUI and then edit the lisp definition. You can also use this with variables/arguments --- your menu macro could be (OpenLsp 1) to open your lisp folder, and (OpenLsp 2) to open the current drawing folder, etc.
0 Me gusta
jwright1962
I'll think on this...  This is a good tip and I'm sure I'll have opportunity to use this method.  I bet if time allows, I could "thin out" the number of utilities I have because lots of them have similar code...just copied from one lsp to another.   Providing a "switch" or "parameter" as you suggest would likely reduce replicating the similar code over and over again.  Thanks.
0 Me gusta
