using shift to deslect
jw7018
Message 1 of 9
jw7018
Greetings,
Sometimes it is easier to select too many items and deselect one or three via holding down the shift to deselect.
My issue is sometimes i am able to deselect as many items i wish to in one click and others i must deselect each item individually.
Is there a setting/process how to deselect all you chose with one click or is this a glitch?....as I've had it both ways, with it out my control.
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
"sometimes" has no fix: is there something else at play perhaps? Like you are using a Window instead of a Crossing Window and not catching all you want to deselect?
Message 3 of 9
ВeekeeCZ
Maybe these options?
Message 4 of 9
jw7018
Could you clarify the difference between a window and a crossing window? thanks
I've added a screen shot of my selected items and of the window I am deselecting with shift command.
Message 5 of 9
jw7018
operating CAD 2013
no Lasso option to select
Message 6 of 9
pendean
Community Legend
Community Legend
>>>... difference between a window and a crossing window...<<<
Watrch the video https://www.youtube.com/watch?v=sXAwSA9glbk
Looking at your 3D view, what exactly are you trying to deslect? Your Crossing Window method seems to be selecting everything you've already selected.
Message 7 of 9
jw7018
that was just a representation of selected items and my selection window........... there were more selected items out of view.
per your video I have been selecting with the proper Implied & Crossing windows. (knew their function....never knew their proper names)
Which brings me back to my original post (sometimes all items will be de-selected with the shift command and  others they have to be selected one at a time.
Message 8 of 9
pendean
Community Legend
Community Legend
"sometimes" has no fix.
Dig a little deeper next time it happens, observe what actions you are doing, try to repeat the problem, see what else can be done.
Message 9 of 9
kite15
Hi jw7018,
Check your PICKADD and PICKAUTO system variable its will be  2 and 1
Sometime using Autolisp and other Add-Ins has been changed the system variable for the performance of the Add-Ins. May its happening after using any Add-Ins by you.  Smiley Indifferent
