Using Point files in Autocad
@Anonymous.bellek
John,  spoke with Monica and she said to contact you reguarding point files.
I started using CAD in LLD 2000i and I was used to using the point files for processing info from data collectors
normally I am able to upload a PNEZD format to get 4 layers (point, point number, elevation, and description)
this version of cad does not offer point files and the info I bring in comes in on one layer.
if there is anything you can do to help (Monica mentioned a script) it would be much appreciated
thanks
Kevin
TerryDotson
Stock AutoCAD does not have provisions for Point files.  You will need to upgrade to Autodesk's Civil3D or consider an add-on for AutoCAD like DotSoft's MapWorks.
Patchy
That was when Softdesk added to Autocad.
Then a year or two after that Autodesk made Points into AEC Point so that option was gone.
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 To do this in plain AutoCAD can be a bit cumbersome.  First you need to see if you can get the point data into an Excel format. If you can provide this to me then we can explore creating a block with attributes to capture the information in the excel file and be inserted into a drawing.
John Vellek
