Using non-plotting layers
Message 1 of 21
Hello, I have a question about using non-plotting layers when drafting. We have a layer that we use for viewports (VPORT) and we often use it for objects that we want to be hidden but not removed. I also often use it for layout lines for drafting objects. I have a habit of forgetting that I have VPORT layer current when inserting blocks or putting in dimensions and they show up on my screen with proper colors, but obviously don't plot to paper.
I'm wondering if anyone has any tips to avoid this, other than the obvious one of just paying closer attention. I am doing my best to eliminate this mistake, but they still occasionally slip through, and I'm seeking a fool-proof solution or edit strategy.
Thanks!
Michael
Replies (20)
Message 21 of 21
ChicagoLooper
To put your dims on a specific layer, you can continue using the Tool Palette. The palette can also execute commands such DIM and put the dimension on a layer specified by you.
Hints:
  1. make multiple tabs in your palette, e.g. one for blocks, one for dims and text, and another tab for hatches . You  may even categorize your blocks and make a separate tab for each block category.
  2. You can even have the same command twice on the same palette, e.g. pline with layer set to ROAD layer to draw roads and the exact same pline command set to BUILDING layer to draw buildings.
To get the Customize User Interface, right click in an empty area of your palette and select CUSTOMIZE COMMANDS from the shortcut menu. Then use the Search function to find the command you wish to put on your palette.
Warning: The Search function in the Customize User Interface is funky. If you don't type in a correct KEY word the results will be funky too. Search using different KEY words until you hit it right.
1-Search for your command, highlight  it blue, then click and drag to your palette.1-Search for your command, highlight it blue, then click and drag to your palette.2-Once it's on your palette, right click icon and change the layer using the dropdown menu in the propeties.2-Once it's on your palette, right click icon and change the layer using the dropdown menu in the propeties.
Chicagolooper
