Using Grips to change layer of object
convds
Message 1 of 8
convds
I used to be able to GRIP and object and using the ribbon layer dropdown in the menu switch the layer of the object to anything on the layer list,  For some reason, this has stopped working.  Is there a system variable that changes this?
I have looked through the help and cannot find this.
Any help would be greatly appreciated.
Replies (7)
Message 2 of 8
paullimapa
make sure under Options>Selection>Selection Mode the following toggles matches:
Paul Li
IT Specialist
@The Office
Message 3 of 8
imadHabash
You may need to check PICKFIRST (System Variable).
Command: PICKFIRST
Enter new value for PICKFIRST <0>: 1
Imad Habash
Message 4 of 8
Valentin_CAD
@convds ,
You may need to elaborate more - your issue is not very clear,
See if these links help:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 5 of 8
convds
Perfect,
Thank you very much.
Geoff
Message 6 of 8
paullimapa
Notice that when pickfirst is set to 0 in the Options>Selection>Selection modes section the Noun/verb selection is unchecked. But once you set pickfirst to 1 and return to the Options>Selection>Selection modes section the Noun/verb selection is now checked.
This is why I told you to match what I showed in my previous reply post.
Paul Li
IT Specialist
@The Office
Message 7 of 8
convds
All Good, Thanks
Message 8 of 8
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
