Using field for layout naming..
mGamalFJH34
mGamalFJH34
CAN I ADD A FIELD IN THE CURRENT LAYOUT THAT CAN GET PREVIOUS OR NEXT LAYOUT NAMES? IS THERE IS ALISP THAT CAN DO THIS?
TomBeauford
No, there are many lisp out there for renaming and sorting layout tabs like Lee Mac's TabSort but you cannot use a field in a layout tab name.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
pendean
Community Legend
Community Legend
If you all actually use SheetSet Manager (SSM), that FIELD ability is built right there and you can use it all day long anywhere you need in your DWG file(s) https://www.autodesk.com/autodesk-university/article/Managing-Your-Sheets-AutoCAD-Sheet-Set-Manager
TomBeauford
Using SSM a sheet name which is a shortcut to that layout tab is an alternative.
2023
