Using batch plot in Autocad 2019
How do you batch plot multiple sheets to single pdf?  I was able to do it in earlier versions of autocad but I can't do it in autocad 2019.  In autocad 2019 it creates a file for each sheet and I can't find a way to change those settings.
Alfred.NESWADBA
run command _PUBLISH, this let you select layouts, select other dwg-files and their layouts and you have the option to create a multi-page PDF, all in that one dialog!
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
