I've never used batch plot before but I have a file that has multiple views set up in view manage in model space that I need to print. I've found instructions on how to do it from paper space but not model. Can anyone walk me thru it?
The Batch Plot icon in the Output tab Plot palette is the PUBLISH command. But it's not intended for use with views in model space. It's used to grab Layouts from the current drawing, from other drawings, or from sheet sets to efficiently put together a job in one quick operation.
If you really do want to plot various model space views you'll want to set them up in Layouts (paper space) views and batch plot them from there. These wouldn't necessarily have to be finish work drawings in formal title blocks... but they could be if you wanted.
Dave
Here's a suggestion for you:
Create a new Viewport in a Layout tab. Then activate it by double clicking inside of it. While the viewport is still activated go to one of your named model space views. Then close the viewport.
Do this in separate viewports on a single layout sheet or in multiple sheets for each of your custom model views.
Once they're all set up run the PUBLISH command and specify the layouts that contain the views. If this is something you will do fairly often save the sheet list with a custom name in the Publish dialog . This is a way for you to batch plot your model space views.
Dave.
alternate possibility , entirely in model space :
in model space , create preset plot views with command _pagesetup .
- save and close your drawing
- start publish command. Empty all dwgs in publish dialog. right click and select import "model views" only .
then follow these steps
1 - drag and drop your saved dwg to the publish dialog
2 - select a page setup .
3 - drag again your saved dwg , acad will ask you to rename the sheet , accept and give it any name .
4 - select a (different) page setup
repeat steps 3 and 4 for as many page setups there is.
save your dsd file
click publish button, all your preset page setup will plot
note : dwf , pdf plot is also available without changing your setups
Best tip ever! Lots of companies don't understand why they should use paper space. So everything gets dumped in model space by default. Which is not bad on its own, but you lose track of scales, proper dimstyles and texstlyes etc. This advice solves that issue !
@mrkaplan : How did you figure this out? It's super clever....
Kudos! Best regards
Great solution. I was wondering if somebody knows how this works in autocad 2020 osx? I'm struggling with the batch publish section.
Arun
@adjansen wrote:Great solution. I was wondering if somebody knows how this works in autocad 2020 osx? I'm struggling with the batch publish section.
For batch printing from Model use this - Revers
