Using autocad viewports
fredJME3H
Message 1 of 29
fredJME3H
I am using autocad 2d for designing a piece of machinery i want to build and I need your input on how to do some
things that I am sure can be done by autocad ( I am using the current version( 2019 i think))
Using model space i am designing an assembly which has many parts.
At present i put each part on it's own layer but this leads to very roundabout activating layers lots of use of zoom before I can print a single part.
is it possible to put each part on a seperate page which is kept up to date as modifications are made to the main
drawing on model space ?
I imagine that each part should probably be on a seperate layout ?
how is this done ?
If changes are made to the layout will these changes automatically update the model space  drawing
all advice and sugestions will be gratefully accepted
many thanks in advance
Fred Evans
Replies (28)
Message 21 of 29
fredJME3H
Hello Solmanu,
were you able to find the filter layer called mixer ?
I downloaded the file and when I opened it- the filter i made is at
home > layers > layer properties > listed under filters as "mixer"
thank you for your .gif. Unfortunenately I am unable to read it because
it goes to fast and the definition on my screen is not that good so I
cannot read the contents of the dropdowns.
Please try again- i would really appreciate it
Many thanks
Message 22 of 29
cadffm
Please share a screenshot of your  Program window while HOME tab and filter is current,
And command: ABOUT dialog is open!
Perhaps you take the wrong file after downloading?
In Autocad 2020 i could not see a filter, and s.faris also not.
BUT.. this is not your problem.
What you need to know is written in the thread.
Sebastian
Message 23 of 29
fredJME3H
>" I have created a layer filter called Mixer and have told it to display all layers
with Mixer*"
But not in the uploaded file...Why?
>> look in the uploaded file home>layers>layer properties manager ( maybe upload again?)
>"I then pressed "set current" hoping that it would only display the mixer layers."
And exactly this happen (The Layer properties-manager list only Layers with the name pattern "Mixer*"
Or not?
>>Yes layer properties manager only lists "mixer" files but the dropdown in the layer tab lists all layers
>"But it doesnt when I click the layers dropdown- it still displays all the layers."
There are layer with names which not fit to "Mixer*" in the drop-down list???
>> yes there are all the layer names
Objects..
Layerfilter have nothing to do with objects and Layerproperties,
layerfilters are only a helper to select layers and filter the layerlist.
>> yes I understand that this is the purpose
If you want to have all layers freeze, except the Mixer* layers (and one of the Mixer* Layers is the current layer),
Yes, you have to freeze all layers and thaw the Mixer layers
Your choose how to do that.
>> I dont know what you mean and how to achieve this
For my standard layers i use my own Button "Only Mixer-Layer ON",
behind the Icon you will find a macro like that:
^C^C^C_.-LAYER;_thaw;"Mixer*";_make;"Mixer Shaft";_freeze;~Mixer*;;
>> how do I find this Button? which icon?
or for invisible, but editable and deleteable, ON/OFF
^C^C^C_.-LAYER;_off;~Mixer*;_on;Mixer*;;
okok, a fake, i would never use blanks in Layernames
>> good idea I will apply this in future
regards fred
Message 24 of 29
cadffm
>">> look in the uploaded file home>layers>layer properties manager"
In your uploaded file here <click>
https://forums.autodesk.com/t5/autocad-forum/using-autocad-viewports/m-p/9251544#M1006155
is NO filter defined.
>"( maybe upload again?)"
If you upload the correct file then, yes - do it.
>">>Yes layer properties manager only lists "mixer" files but the dropdown in the layer tab lists all layers"
For drop-downs, you need to active this option.
Go to LAYERproperties-Manager, upper right corner, there is a "Tool"-Button,
in this dialog near to the end you will find this setting.. filtre apply to..
I guess the standard setting for this is ON, but perhaps on your program it is set to off, change it to ON.
>">> how do I find this Button? which icon?"
Made myself and you can do it yourself..
For example: Go to Toolpalette [CTRL+3], Tab Commands
Copy&paste this sample [Right click context menu on this item]
Rightclick on the new one, properties.. there you can add my sample macro
Sebastian
Message 25 of 29
S.Faris
Follow the below provided steps
SALMANUL FARIS
Message 26 of 29
cadffm
I guess to know your mistake!
Perhaps you set a temp filter for the layerproperties palette?
In the upper right corner is a field where you can set a filter "mix*"
but this is temporary in your program session, not stored in the
DWG and ONLY for this palette.
We talking about "named layerfilters" like the standard one on the left side of your palette, "all used layer".
http://help.autodesk.com/view/ACD/2020/ENU/?guid=GUID-46F22B6E-D087-4AB4-8D4F-580E0E75FAD3
HTH ??
Sebastian
Message 27 of 29
fredJME3H
To Both Chaps - I am going into a meeting and I will report back later
regards
fred
Message 28 of 29
fredJME3H
Hello Solmanu !! thanks this seems to have done the trick
two things that I did which may have been influential.
1.In the "settings" gear on the top right of the layer properties manager screen I ticked :-
"new layer notification " ON;
"evaluate new layers added to drawing"ON ;
"Isolate layer settings" "lock and fade" ON;
"dialog settings" both ON
2. After defining the new layer "mixer" - rt clk new layer > isolate group>all viewports
Now it seems to do what I am after
so thank you for all the help it is really appreciated and the result will make my autocad
experience mush more useful
regards
fred from south africa
Message 29 of 29
fredJME3H
Thank you - see my post to solmanu with more detail about the solution
many thanks
