Anuncios
Using autocad to turn grasshopper generated objects into components?
No aplicable
Hello!
I have been using grasshopper this morning for some basic parametric work. From a spread of points in Rhino, I generated small rectangles as curves (lines for those of you unfamiliar with Rhino). I need to make these squares into components, such that each square is an instance of the same component. However, Grasshopper does not allow me to generate these as components/blocks.
Does anyone know how I could use AutoCAD to convert a large number of rectangles to instances of the same component? They are all the same size. A coworker of mine says it can be done but doesn't know how.
Much thanks to anyone who can answer my quandry!
BW
0 Me gusta
Responder
713 Vistas
1 Respuesta
Respuesta (1)
No aplicable
Alternatively - If I could skip grasshopper entirely and just convert the points generated in rhino into instances of the same block in AutoCAD, that would work!
0 Me gusta
