Using absolute cordinates
mechdesign21
mechdesign21
How do i move something like I have shown below,  i have done it for years it does not work now for some reason.
command: move
pick object<enter>
endpoint<enter>
0,0,0
and it would move to 0,0,0.  Now I broke it and this does not.  what needs to be clicked to set it right again.
thanks,
Accepted solutions (4)
dbroad
If you're using dynamic input, the default is relative coordinate entry.  Either turn that off or use an absolute prefix(the asterisk), such as:
*0,0,0
Architect, Registered NC, VA, SC, & GA.
jstanczykGDWT4
Enter MOVE on the command line.
Select the objects and press Enter.
Select a base point for the objects.
Enter #0,0 for the second point.
Not sure how long ago (seems like a while) and not sure why, but AutoCAD now requires the # symbol to place objects at the origin.
vinodkl
Hello @mechdesign21
Type in the command DYNPICOORDS and set it to "1". See if that helps 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
cadffm
If you like to work in dynamic input mode(dynmode is set >0), see all replies above
* and the main setting dynpicoords [F1]
or you like to work in classic input mode: Turn off your dynamic input.
You can use the toggle [F12] - it does set dynmode to a negative value  what means "off"
Sebastian
mechdesign21
thanks so much!!
mechdesign21
nice!! thanks again
