Anuncios
User cannot explode inserted blocks
kstate92
kstate92
We have a user working remotely that has run into a problem we can't figure out.  We had set him up with a copy of our library of non-dynamic blocks we've used for decades, but he cannot explode them after insertion:
I have been trying to insert other symbols with the same results.  I can bring the symbol in and position it, rotate it, mirror it, and even copy it to another location.  When I go to explode the original or the copy, it states:
Select objects: 1 found
1 was an external reference.
I have searched on line and not really found anything matching, other than instances of a specific block created with the cannot explode flag set, which we never had set (or was aware of, TBH), but this is every block he tries.
I'm a little fuzzy in recalling, but we basically set up a SSD with the same files and paths we already have, but re-mapped to the SSD drive letter instead. Perhaps it's a permissions thing, but would read-only block files be transparently converted into an xref?  I can't find any definitive proof of this.  I've asked him to check the Xref dialog after a block insertion to see if it is showing as an xref but haven't heard back yet.
KState92
Inventor Professional 2020
AutoCAD Mechanical 2022.0.1
Windows 10 Pro 64 bit - 1903
Core i7-8700 32 GB Ram
Quadro P2000
0 Me gusta
Responder
575 Vistas
4 Respuestas
Respuestas (4)
pendean
Community Legend
Community Legend
"1 was an external reference" is a clue that your block is actually an XREF: it needs to be bound first as an "insert" to explode it.
Start the XREF command and see what is going on.
imadHabash
I'm curious to know more about this issue ... BUT while i reading your issue a lot of ideas jumps :
  • MINSERT command has this behavior , i mean blocks cannot be exploded and cannot deal with annotative blocks.
  • did he check Allow Exploding in the Block Definition dialog ?
  • if he close AutoCAD and reopen a new empty CAD dwg , any changes ?
  • Attached xref instead of a Block …  this is weird ?!!!  maybe working remotely cause that !!! i don't know .
Imad Habash
0 Me gusta
kstate92
It's done through an old school image tile menu system (^C^C-insert "file path & name" \1;1;0) which works for us locally without issue.  Probably is some mapping or permissions issue but the results of an insert / explode seem odd at best.
KState92
Quadro P2000
0 Me gusta
RobDraw
The first thing I would check is the properties of the blocks within the drawing. Are they blocks or XREFs? The answer will determine how to proceed.
Rob
0 Me gusta
