use the drawjig methods to draw double ployline
I use the vb  .net to realize the double ployline;the two line have a distance for what user give ,i also see many books ,but i want realize the fuction just like the command "pl" in cad,now i can draw the single ployline with my program,maybe i do not totally unstand the drawjig,can  u give me some ideas?thank u very much
Balaji_Ram
The drawjig is not limited to a single geometry. So in the WorldDraw, it should still be possible to draw as many entities you want separated by the offset.
What issue do you have exactly in creating a double polyline from your draw jig ?
This blog post should help and it draws multiple geometries in a draw jig:
http://through-the-interface.typepad.com/through_the_interface/2010/03/using-a-drawjig-from-f-to-cre...
You can also try jigging a multiline with the multi-line style deciding the offset between the lines.
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
