Use same attribute multiple places in a block
mfynaard
Message 1 of 12
mfynaard
I am looking for guidance in how to create a single attribute and have that attribute's value be displayed in multiple places in the same block. I only want to define it once so that if the user modifies the value, the updated value appears in all of the places it is used.
Replies (11)
Message 2 of 12
chriscowgill7373
someone might have to help me out on this one, as I've only ever seen it done, but not actually done it.  What about using a field that references the value of the attribute, so when it changes, all the other fields update?
https://forums.autodesk.com/t5/dynamic-blocks/fields-object-attribute-value/td-p/3182708
https://forums.autodesk.com/t5/autocad-forum/attribute-reference-another-attribute-within-a-block-bl...
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 3 of 12
mfynaard
I'm not sure that is really what I want. I have read through many similar posts and was not able to make it work. I have attached a screenshot to help explain. In the picture are wire numbers. I want to substitute the text before the underscores based on the single attribute.
For example, shown is LI01_00, LI01_01.....
If i change the attribute to RO02 the values should change to RO02_00, RO02_01.....
Is that more clear?
I tried doing the things mentioned above and cant get the fields to update.
Message 4 of 12
Ranjit_Singh
See attached example. You will have to insert the block and link the attributes. Then use a copy of this new block as needed. Inserting the original block will not function unless the attributes are linked again.link_attributes.gif
Message 5 of 12
mfynaard
Thanks for your response! I was hoping for a way to link the fields in the block definition in my library so that when I insert the block to a new drawing I am prompted for the value of the attribute and the fields update.
This is not possible?
Message 6 of 12
Ranjit_Singh
As far as I know the attributes can be linked, but not the attribute definitions (in the block definition).
A possible work around is to create a nested-block with your modified block (where attributes are linked). Give it a logical name (different than your original block), say, atts_linked_block. Now save this in your blocks library. Use this new block for insertion in any new drawing. Once inserted explode and you have your original block with linked attributes.
Message 7 of 12
mfynaard
This does work. I am going to use this method for now. My concern is that I am going to be distributing my symbol library to coworkers when they are finished and having the 'explode' stipulation on some blocks may be a cause for headaches later. Thank you for your help with this.
Message 8 of 12
cadffm
@mfynaard
How do they insert the blocks? If YOU decide how it is inserted, then it is up to you:
1. A menumacro (attached to a tool/button of your choose: toolbar,ribbon,menu,toolpalette)
2. for Toolpalettes there is a second  option: A  "insert tool" with option explode=yes
(it is not working by insert command or insert via designcenter)
Sebastian
Message 9 of 12
mfynaard
Typically we use Design Center and this is not working unless i nest the block and then explode once inserted.
Message 10 of 12
maik.ruppelt
Hello Ranjit,
can you explain in more detail how to create such a block with linked attributes.
I need one that contains several linked attributes and would like to create one.
Thank you very much.
Message 11 of 12
dustinZSR6N
Community Visitor
Community Visitor
The instructions say to insert the block and link the attributes.  How do I link the attributes?
Message 12 of 12
cadffm
by using FIELDs.
Editing the attributvalues of your inserted blockreference,
rightclick -> insert field
Use field category object
Type object
[select this blockreference]
Select the property [Name of the main Attribut]
If you never used fields, search gir YT videos
but the dialog and options fir this case is very simple
Sebastian
