AutoCAD Forum
Use a dynamic block as reference to another objects dimensions (in retrospect)
1 REPLY 1
mmatanlevi
134 Views, 1 Reply
Let's say I made a rectangular dynamic block which have a one linear stretch on one side (image attached). I use this block for several different rectangles, and now (after the block is made and appear in the drawing in several dimensions), I would like to add to the block another rectangle which is actually an offset of 5mm from the block. If I do it (adding offset rectangle on block editor), the offset is not keep as I want in all the dynamic blocks. I mean, adding an offset to dynamic block after it made, do not keep the same offset in all the dynamic block different appearances. I would like to know if someone have an idea.
Thank you very much!
1 REPLY 1
j.palmeL29YX
in reply to: mmatanlevi
I'm not sure if I understand you right. Attached a block, where in addition to the width also the height and the offset can be changed.
What you've asked for ("reference to another objects dimensions (in retrospect)")) is not possible IMO.
Jürgen Palme
Forma Design Contest
