Upon startup, AutoCAD loads default template into model space instead of paper space
benT9WUK
benT9WUK
My intent is to boot AutoCAD directly into a paper space layout in my template file.
Currently, upon boot AutoCAD loads the file into model space, however, if I click the QNEW button the file loads into paper space, as intended.
This is despite all workspaces being set to start on Layout.
Is this an unavoidable quirk of the AutoCAD startup procedure, or is there some way to get this working?
0 Me gusta
Responder
417 Vistas
6 Respuestas
Respuestas (6)
imadHabash
I suggest to check STARTUP (System Variable) that may guide you for some thing.
Imad Habash
0 Me gusta
benT9WUK
Thanks for the reply,
I've tried all four options in the STARTUP variable, put none have changed the behaviour.
0 Me gusta
pendean
Community Legend
Community Legend
This classic old tip still works, give it a shot https://allaboutcad.com/open-autocad-with-a-specific-template/
0 Me gusta
benT9WUK
Thanks for the suggestion, I tried that too but had the same result of the template file opening to model space rather than paper space.
0 Me gusta
pendean
Community Legend
Community Legend
Share your template file here for others to test with please.
0 Me gusta
TomBeauford
My guess would be something in acad.lsp since it only runs on startup by default. If it called switching to Model Space it would only happen when AutoCAD starts up.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
0 Me gusta
