Anuncios
Upgrading from AutoCAD 2017 to 2019
patrick.odonoghue2
patrick.odonoghue2
Hey guys,
I currently have the student version of AutoCAD 2017 that I downloaded back in 2017.
Would I be able to update to AutoCAD 2019, or would I have to download the 2019 Student Version again?
0 Me gusta
Responder
Soluciones aceptadas (1)
8.296 Vistas
14 Respuestas
Respuestas (14)
john.vellek
Hi @patrick.odonoghue2,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 There is no difference between an educational and a full version of AutoCAD other than the licensing you apply to it.  If you are still a student and eligible for continuing your educational usage, you should be able to use the full version of 2019 as long as you apply appropriate licensing to it.
John Vellek
patrick.odonoghue2
Thanks for the reply John!
So just to double check - will I update through the application I have on my PC at the moment, or must I download it again from the website?
0 Me gusta
cadffm
Why you wrote "AGAIN"? If you want to have 2019, you have ti install 2019 (before you have to download 2019, which is another program!)
- download
- install
- happy (if you have a 2019 license, which I can not verify)
Sebastian
GrantsPirate
Realize that the 2019 Student version will plot the EDU stamp on all four sides of the page.  Although an instructor should have no problem with that, some object to the aesthetics of the plot.  As you know 2017 Student version doesn't plot with the EDU stamp.  You are only allowed to use student versions for educational purposes and not for commercial projects, so from that standpoint it doesn't matter which you use.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
patrick.odonoghue2
Perfect - sorry just one more question: will I uninstall 2017 before
downloading 2019, or will they automatically go together when I download
2019?
0 Me gusta
Alfred.NESWADBA
you can have both installed, 2017 as well as 2019 (and also both will work as long as your licensing is ok with that).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
beyoungjr
Solución aceptada
Here is the solid answer to your question...
You should login to your Autodesk Education Community account using the same credentials as prior.  You will be able to download and install AutoCAD 2019 and other products with educational licensing.
Also, many professional keep old versions of AutoCAD installed but I typically recommend that students uninstall ALL old versions of software because their PC's are usually not as high performance as in professional working environments.  You will save headaches by removing the old versions.  Be sure to use the Autodesk Uninstall tool in your programs folder and then check your installed programs or apps manager to see if any residual items remain to be uninstalled.
Lastly, if you have customized AutoCAD you may wish to backup your customization (workspaces, menus, toolbars, etc...) using the CUI command before uninstalling.  You can also backup any of your own templates you might have saved in the templates folder.
Hope this helps,
Blaine
Blaine Young
Senior Engineering Technician, US Army
john.vellek
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
0 Me gusta
joe.herrity
Observer
Observer
i NEED TO ENTER MY ADMINISTRATOR PASSWORD FOR THE INSTALL. thE BOX TO DO THIS IS NOT COMING UP WHEN USING THIS PROCESS. HOW DO i DO THIS.
0 Me gusta
beyoungjr
Sounds like a Windows Admin issue, right?
Blaine Young
0 Me gusta
No aplicable
I have the same question since that I am having some issues with scaling for the 2017 version because I am using the application on a device with a 4k screen monitor. The the letters on the drawing screen are very tiny and I seem to not find a solution that can fix it. Also, I have read online that the 2017 version does not support 4k screens, anyhow I just wanted to find out whether I have to download the latest version on the website or is there a way to download it from the AutoCAD application.
0 Me gusta
ennujozlagam
hello, have you try to change your windows display setting  (+ -  ) 125%- 150++%  and see if helps. thanks
Alfred.NESWADBA
Install the update AutoCAD 2017.1.2, that has improvements for higher resolutions and support of Windows DPI-scaling.
- alfred -
Alfred NESWADBA
No aplicable
I have tried that but it does not seem to fix the problem so I installed the latest version instead. Thank you for the help though!
0 Me gusta
