Here is the solid answer to your question...
You should login to your Autodesk Education Community account using the same credentials as prior. You will be able to download and install AutoCAD 2019 and other products with educational licensing.
Also, many professional keep old versions of AutoCAD installed but I typically recommend that students uninstall ALL old versions of software because their PC's are usually not as high performance as in professional working environments. You will save headaches by removing the old versions. Be sure to use the Autodesk Uninstall tool in your programs folder and then check your installed programs or apps manager to see if any residual items remain to be uninstalled.
Lastly, if you have customized AutoCAD you may wish to backup your customization (workspaces, menus, toolbars, etc...) using the CUI command before uninstalling. You can also backup any of your own templates you might have saved in the templates folder.
Hope this helps,
Blaine
Blaine Young
Senior Engineering Technician, US Army
