Updating layout according to pointcloud
I work with pointclouds & industrial 2d layouts where we mainly try to update the building outer/inner walls & Pillars to match reality.
When working with multiple connected buildings its impossible to align the PC to the drawing, I know there could be multiple factors to why this happens but I'm trying to figure out the correct workflow (if there is any).
so I started with the building to the right (red) and aligned the PC using a wall. Moved tome pillars and inner walls but didn't have to move any outer walls. The problem is noticed later when updating the left side buildings where I would have to update the outer walls to get it to match the PC which means I would have to move all other layers in the master dwg file which is a lot.
Does anyone have any tips on the workflow here? Is it even a good idea to update 2D drawings according to point clouds instead of drawing from scratch?
Should the buildings perhaps be separated and not act as a single building?
Appreciate all tips you have regarding this type of usecase
