& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Hi
Is there any way to update all hatch, within blocks (also Dynamick blocks)
This is just an example, where block 1 is copied, but the hatch does not allign, and i cant use hatchedit, because it is within the dynamick block.
as much as i understand that you want the diagonal hatch2 to be continuous with the hatch1 . if that is your case then you can not achieve it since you're treat with a block .
Imad Habash
That was what i was afraid of, thanks for the fast reply 🙂
There is a thread in the dynamic blocks forum between @Libbya and myself that might help which involves rotation, scale, stretch as well as origin. I'm terrible with linking and cross posting but you could search "hatch scale and origin control" and hopefully it will come up. I've attached the example I am working on as a reference.
I found the thread, and it does help me out, that is actually clever thinking 🙂
Now I just missing the opton to mirror (flip) the hatch (ANSI31), but i will look into that.
(EDIT)
That was just the flip option, but without the hatch 🙂
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
