Anuncios
Unused Dimstyle won't purge
neaton
neaton
I have dynamic block that has an unused dimstyle (CCP-Dim Style) but when I purge the drawing it says the style is in use. Can someone find it for me so I can get it deleted?
Steps I have taken:
Opened the drawing without opening the block editor and purged it.
Opened the drawing with the block editor and done a QSelect search for any dimensions and the only ones are parametric and dynamic dims.
WBlocked it to a new file.
Nancy
0 Me gusta
Responder
Soluciones aceptadas (1)
541 Vistas
6 Respuestas
Respuestas (6)
pendean
Community Legend
Community Legend
If I CTRL+A a bunch of hidden dimensions appear.
BTW you have Constraints in use in your file: is that deliberate, or an accident?
0 Me gusta
Cadologist
Solución aceptada
It appears that you have a nested block within the dynamic block (Casting DYN.dwg) called StructSteps-tops.dwg,which has a purgable dimstyle CCP-Dim Style contained within it. If you PURGE that item out of the StructStep-tops block it'll should be gone.
Chad Franklin
neaton
Yes, it is a dynamic block and that is how it is constrained to act the way it does. The dimensions you see are the constraint and dynamic dims and they don't use dimstyles.
0 Me gusta
neaton
Thanks! I had purged the steps block and could have sworn I redefined the cleaned up block but when I wblocked it out of the castings file it still had the unused dimstyle.
0 Me gusta
Cadologist
Hey glad that was a relatively simple solution..... those "unused" entities can be a real hunt to try and track down what is apparently using them. Block definitions seem to be a wonderful hiding place for these things. Have a great day!!
Chad Franklin
0 Me gusta
user181
I see you figured it out. Seemed to me it was in the constraints. I attached a revised block just in case.
0 Me gusta
