unloading a partial menu
MKH-VB
MKH-VB
trying to unload a partial menu. Have done it thru the menuload command, and have also tried the unload option in the CUI.  Each time I restart autocad, the menu I have tried to uninstall shows up again. I have never seen this done before. Any idea what might be happening ? Thanks for any replies.
MKH
mkh
cadffm
some,
1. Is it "your" cuix, did you load this cuix as partial menu by Hand first?
if yes, did you add some code to reload this menu?
If not, perhaps it is from an app/3.part program?
Whats the name of the file, what functions/commands are inside?
Check this question: Start your product in /safemode, what product you talking about?
Detach the cuix, close the product.
Re-Start  by this way: For example AutoCAD 2019,
[Win]+[R]
Open: "C:\Program Files\Autodesk\AutoCAD 2019\acad.exe" /product ACAD /safemode
Still a problem, cuix appears again?
2. Another try:
   check the edit-date/time of your main cuix file
    detach the file, close Acad,
    changed?
    Open Acad again, cuix appears again? -> check the edit-date/time of your main cuix file
Sebastian
pendean
Community Legend
Community Legend
Do you have a startup or a corporate profile that is auto-loading your menus back for you?
Or is this a 3rd party add-on that probably needs to be uninstalled first?
MKH-VB
it is a 3rd party app. Even after I uninstalled it, I still see the toolbars for it.  So I re-installed it, and same result. Not working.....With the errors I get, I would have thought it was just a file path in my options, but I have checked it too.
mkh
scot-65
Is the menu part of a BUNDLE?
If so, look in the Support Files Search Path in the OPTIONS dialog
for a path/name that may include the phrase "bundle" (+/-).
Using your favorite file manager, browse for and locate the bundle
package and rename the file extension from ".bundle" to ".bundle_X".
Remove that support path from AutoCAD.
Command MENULOAD or CUILOAD and unload the menu.
Restart AutoCAD.
Simply unloading the partial and/or removing the support path for
these bundle packages will not work - they will rebuild themselves...
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
cadffm
>"So I re-installed it, and same result. "
Now DEinstall it again,  detach the menu file,
close and re-open Acad, still a problem?
Search for the app here:
C:\Users\AppData\Roaming\Autodesk\ApplicationPlugins\
C:\program files (x86)\autodesk\applicationplugins\
Sebastian
pendean
Community Legend
Community Legend
Which add-on is that? Did you try their support?
Any reason, if you are well backed up, not to just reset AutoCAD to start fresh with a quick reload of your personal well organized customizations?
