01:53 PM
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
If you select the object, what does Properties show? Can you share your file? I would like to see if this is a map insertion/location point or something else.
It is called a geomarker. The geomarker is used to geo-reference, or position, entities in modelspace. References include, but are not limited to, State Plane or latitude/longitude. Imagine that modelspace is a flat, as opposed to a curved or spherical, representation of the earth's surface and the drawing entities that you create, insert or paste into modelspace will need a reference point to play against. The geomarker is created in Map 3D/Civil 3D when a coordinate system is 'assigned' such as when using MAPCSASSIGN command.
To turn it off, type GEOMARKVISIBILITY on command line then enter 0 for OFF (or 1 for ON).
Geomarker symbol shown in red.
Chicagolooper
Hi @Anonymous,
I am coming back to your thread to see if the issue or question you posed has been resolved. If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
