Units Setup in AutoCAD 2021
lishneva
Observer
lishneva
Observer
Observer
I am struggling to figure out how to draw in cm on AutoCAD 2021. In the Drawing Units menu I set it to Decimal in Length Type and Centimeters in Insertion Scale. When I draw something it is not clear if its in cm unlike when I draw in inches/feet. When I convert it to inches/feet to check if the length is correct its way off.
0 Me gusta
Responder
581 Vistas
5 Respuestas
Respuestas (5)
qnologi
0 Me gusta
Alfred.NESWADBA
You decide the units you want to have active, if you want to draw a line with 1 length and for you this line is 1cm then you have to set the units to "Centimeter".
If you want later to draw a line with 1 Inch length then you need to draw a line with 2.54 length as this is the conversion from cm to Inch.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
lishneva
Observer
Observer
I am using AutoCAD 2021, the video is based on 2015
0 Me gusta
lishneva
Observer
Observer
I need to draw in cm. How can I make sure I am drawing in cm in AutoCAD 2021?
0 Me gusta
Alfred.NESWADBA
Command _UNITS ... set the "Insertion scale" to "Centimeter" .. same can be done via system variable INSUNITS.
- alfred -
Alfred NESWADBA
0 Me gusta
