Anuncios
Unites
Unites
No aplicable
How do I change the units so when I type a line length it will be in millimeters
0 Me gusta
Responder
Soluciones aceptadas (3)
454 Vistas
4 Respuestas
Respuestas (4)
No aplicable
Solución aceptada
Dear Mr.Acs
In command window,  type "UNITS" and choose the insertion scale you want from the drop down dialogue box.
Hope this might have helped you..
Regards
Di****h
0 Me gusta
imadHabash
Solución aceptada
select your needs from DDUNITS command dialog then start your drawing with millimeter inputs.
Imad Habash
0 Me gusta
john.vellek
Solución aceptada
Hi @Anonymous,
Welcome to the Autodesk Community!
To adjust your units, try using -dwgunits and units. Here is an AKN Article that describes how units work in AutoCAD.
John Vellek
0 Me gusta
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem or if you need additional information and resources.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
0 Me gusta
