Anuncios
Unite!
je2525
Unite!
je2525
UNITE
I came across this command by accident (typo).  I can find no reference to it in the help file or on the web.  Can anyone enlighten me?
0 Me gusta
Responder
312 Vistas
4 Respuestas
Respuestas (4)
imadHabash
UNITE command doesn't exist in normal AutoCAD installation .. BUT there is alternative command called JOIN is the equal command . >> Click <<  OR you have an outsource lisp routine that represent this command .
Imad Habash
0 Me gusta
je2525
See the attached image. It does (or did) appear to be a command... UNITE
renamed to JOIN? That is what is perplexing.
0 Me gusta
Patchy
Either in .lsp or .pgp
You can find it there.
0 Me gusta
Kent1Cooper
It's an alternative command name.  There are others [for example, DELETE (spelled out -- not the Delete key) is not listed as a command name in Help either, but it works, giving you the ERASE command].  The command line shows the "real" command name you're going to get when you type one in:
But I haven't been able to find a listing of them, either, maybe because I don't know what they're officially called [except not "alias"] -- are they "alternative" command names? "substitute"? "equivalent"? "stand-in"? "proxy"?
Kent Cooper, AIA
