Unit Symbol Changed from script input
I am at a loss trying to figure this one out.  I use a script to import notes and details to my drawing template.  For some reason, I am getting odd symbols (â€, Â).  â€ seems to be replacing the inch unit (").  Â is being added before degree (°) symbol & superscript text (²).
Is this a setting that needs to be adjusted.  Between different users, we are not seeing any consistency in the issue.
pendean
Community Legend
Community Legend
What font is in use in that DWG file? Looks like you ended up with symbols coded in that TTF font.
I am currently using Arial Narrow font for this mtext.
pendean
Community Legend
Community Legend
Can you test with other fonts, starting with an SHX then other TTFs like Times Roman perhaps?
Can you post your script here for others to test and confirm what ABOUT command shows to be your AutoCAd variant/version?
hi,
Reason is Very Simple.  always use Unicode while script
Degree = %%D
Inch  = \U+0022
 Square = \U+00B2
Thanks and Regards,
Hari Nair [Master From Lost Nalanda]
Facebook|Youtube|Gmail
