union command
union command
union command
can anyone tell me the opposite command for the "UNION comand" in other words is there any a comand for  deunion
Alfred.NESWADBA
sorry no, not as long as those 3D-solids are "one-in-another" or at least overlapping.
The chance you have is to use <CTRL>-<CLICK> to select one of the 3D-solids that are part of UNION, then move that part away from the other part. And when the parts are not overlapping you can use command _SOLEDIT with options _BODY ==> _SEPERATE. (in the menu it's called "Seperate".
Just to make sure: the subobject handling can only work when SOLIDHIST was on.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
thank u
