Anuncios
Uniform Scale in Insert dialog
No aplicable
Which system variable controls the toggle 'Uniform Scale' in the Insert dialog ?
I found a lot of posts regarding 'Uniform Scale' in a block defenition.
This is NOT what I am interested in !
Responder
Soluciones aceptadas (1)
589 Vistas
4 Respuestas
Respuestas (4)
Muhammed.OPERA
Hi @Anonymous
I think there isn't such system variable.
You can see the system variables concerning blocks here:
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoCAD-LT/files/GUID-91EBC702-B874-4400-83E2-B134099B2974-htm.html
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
0 Me gusta
imadHabash
>> Which system variable controls the toggle 'Uniform Scale' in the Insert dialog ? <<
There is NO system variable for this Uniform Scale ..
Imad Habash
0 Me gusta
chriscowgill7373
I think it just remembers the last setting, which means there may be a registry hack you can control it with, but not necessarily a system variable.  is there a particular reason you are looking to control this box?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
0 Me gusta
vladimir_michl
Solución aceptada
Its is controlled through a registry variable (value). You can preset it with a LISP code:
;enable Uni
(defun c:InsUniform ( / profile)
 (vl-load-com)
 (setq profile (vla-get-ActiveProfile (vla-get-Profiles (vla-get-preferences (vlax-get-acad-object)))))
 (vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" profile "\\Dialogs\\insert_dialog") "ScaleUniformly" 1)
;disable Uni
(defun c:InsNonUni ( / profile)
 (vl-load-com)
 (vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" profile "\\Dialogs\\Layerinsert_dialogDialog") "ScaleUniformly" 0)
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
