unhandled access violation writing 0x0000 exception at fd2cbb61h
agajardoc
agajardoc
Please your help
unhandled access violation exception 0x0000 writing at fd2cbb61h
any solution
0 Me gusta
Responder
2.323 Vistas
8 Respuestas
Respuestas (8)
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
When does that error appear? What are your system info's (operating system, graphic card + driver), what product do you have (which AutoCAD version and/or vertical and servicepack).
As I'm not sure to have seen a writing exception like you wrote from AutoCAD itself can you create a screenshot and upload that screenshot from the error info?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
wispoxy
Issue:While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:Fatal errors can have a variety of causes.  They often indicate a corrupt drawing, a program corruption,  or a problem with your system configuration.
Solution:There are several ways to troubleshoot the problem:
If all the above solutions fail, you may need to ask the Community forum or contact Autodesk Customer Support.
0 Me gusta
No aplicable
Hi
  The fatal error happened:Unhandled Access Violation Writing 0x0000 Exception at 5181e3d6h
When i want to open  JC ,the error appear.,see the following screenshot. WIN10
Please your help. THANKS.
0 Me gusta
Alfred.NESWADBA
So that happens only with one specific drawing?
Start AutoCAD (just an empty drawing), run command _RECOVERALL and select this drawing and see if there are errors (which hopefully get cleaned).
As you are using Windows 10 make sure you have installed AutoCAD 2016 SP1 >>>click<<< as this seems to have some issues solved that might happen with Windows 10.
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
Hi
 I opened not a drawing, it's a short-cut icon JC, Only when  i open it , that error appear. but when i open a drawing, it's ok,
thanks.
0 Me gusta
Alfred.NESWADBA
Ok, thank's for clarifying that.
If you first use Windows explorer to go into that linked folder and double click then a DWG inside that folder ... can that be opened then?
- alfred -
Alfred NESWADBA
No aplicable
Hi: Following you method,First use Windows explorer to go into that linked folder and double click then a DWG inside that folder ... that can be opened . thanks.
0 Me gusta
No aplicable
i also facing same problem with win10.
it's autoCAD 2015 cannot use in win10??
0 Me gusta
