unexplodable block
unexplodable block
jdfnnl
Message 1 of 8
unexplodable block
jdfnnl
I created a block from a tiff image. Reason being is that images seem to jump on top of other objects at certain junctures and turning objects into blocks can help to retain drawing order. This image however I am unable to explode back from being a block to an image.
Replies (7)
Message 2 of 8
imadHabash
As you can see .. we just notice a raster image, there is NO block!!
Imad Habash
Message 3 of 8
jdfnnl
here is the block
Message 4 of 8
imadHabash
Type Block command >> Select your block " parcel " >> Tick Allow exploding option then redefine the block .. solved .
Imad Habash
Message 5 of 8
paullimapa
follow these instructions to change the block to be explodable:
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Au...
Paul Li
IT Specialist
@The Office
Message 6 of 8
jdfnnl
it seems like these block settings in properties may be unavailable in ver 2015?
Message 7 of 8
paullimapa
should be there..per Autodesk that setting was added in 2006:
Block cannot be exploded in AutoCAD or AutoCAD LT | AutoCAD | Autodesk Knowledge Network
Paul Li
IT Specialist
@The Office
Message 8 of 8
paullimapa
also make sure you are inside the block editor otherwise you won't see that setting..follow the instructions I posted earlier
Paul Li
IT Specialist
@The Office
